Choose more comfort and enjoy the excellent displays of the Acer KA series. The displays are gentle to the eyes with short response time and special technologies to reduce glare and reflections.
Great visuals
See clearly with a beautiful Full HD display. A fast response time reduces ghosting and takes action-packed entertainment to a new level. -
Optimized comfort
Sit back and get comfortable with Acer ComfyView technology to reduce reflective glare. Get a good view with convenient -5° to 15° tilt adjustment. -
Smart design
On-screen display buttons are conveniently located on the front of the device for easy access. The KA series is wall-mountable and has space for a Kensington lock for added security.
- Acer KA240Hbid - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 26 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.277 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Black
- 56.7 cm x 19.2 cm x 43.5 cm
- 3.74 kg
- MPR II
- Display Type
- Energy Class
- Class B
- 38 kWh
- 26 W
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.277 mm
- Pixel Per Inch
- 91.8
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Bezel Type
- Raised
- Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut, ComfyView
- Black
- 56.7 cm x 19.2 cm x 43.5 cm - with stand
- 3.74 kg
- VGA , DVI , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x VGA cable
- MTBF
- 30,000 hour(s)
- MPR II
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 20.9 Watt
- Power Consumption Stand by
- 0.45 Watt
- Power Consumption Sleep
- 0.45 Watt
- 0.35 Watt
- On / Off Switch
- No
- Shipping Width
- 62.9 cm
- Shipping Depth
- 42.2 cm
- Shipping Height
- 12.1 cm
- Shipping Weight
- 5.35 kg
