Acer KA220HQ 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: BK5CWS00 Mfr#: UM.WX0EE.001
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
More than 50 in stock
£58.02 ex VAT
£69.62 inc VAT
Eco-friendly Acer K2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management.
The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment. Set the K2 Series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
Acer KA220HQ - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
38 kWh
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
50.8 cm x 16.4 cm x 40.24 cm
Microsoft Certification
Compatible with Windows 7
MPR II
3-year warranty
Display Type
Energy Class
Class B
38 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
50.8 cm x 16.4 cm x 40.24 cm - with stand
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
Security Slot Type
Kensington security slot
AC 120/230 V
19.5 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 16.4 cm - height: 40.24 cm , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm
Limited warranty - 3 years
Acer KA220HQ 21.5 Bundle deal on Acer KA220HQ 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
£149.56
Accessories (7)
BK5C StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.11
BK5C StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
BK5C StarTech.com Articulating Monitor Arm In Stock £101.86
BK5C StarTech.com Dual Monitor Stand In Stock £69.36
BK5C StarTech.com Cubicle Monitor Hanger In Stock £45.29
BK5C StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
BK5C StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Other bundles (7)
BK5C C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BK5C C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.54
BK5C C2G 5m Select High Speed HDMI with Ethernet In Stock £22.11
BK5C C2G 10m Select High Speed HDMI with Ethernet In Stock £42.46
BK5C C2G 15m Select High Speed HDMI with Ethernet In Stock £56.74
BK5C C2G Pro HDMI to VGA Converter In Stock £53.02
BK5C C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 50 - 100
