Eco-friendly Acer K2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management.
The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment. Set the K2 Series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
Full-featured for everyone
Eco-friendly Acer KA2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connexion ports, superb performance, and eco-friendliness - all at a price point that'll make you smile. -
Stunning performance
You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution. The great sights are made even better by exceptional colours via Acer Adaptive Contrast Management. -
Comfortable views
The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colours for you viewing enjoyment. -
Smart design
Set the KA2 Series' display angle to optimise your view with its ergonomic stand that tilts from -5 to 25 degrees. -
Environment-friendly
Safe for you and your world, KA2 Series monitors feature mercury-free white LED backlighting and meet ENERGY STAR 6.0 requirements. Acer EcoDisplay technologies use arsenic-free display glass, further protecting the environment. Acer packaging is also made of recyclable materials.
- Acer KA220HQ - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 19 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 50.8 cm x 16.4 cm x 40.24 cm
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 38 kWh
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Black
- 50.8 cm x 16.4 cm x 40.24 cm - with stand
- VGA , DVI , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 19 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 18.1 Watt
- Power Consumption Stand by
- 0.45 Watt
- Power Consumption Sleep
- 0.35 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 50.8 cm - depth: 16.4 cm - height: 40.24 cm , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm
- Limited warranty - 3 years
