Acer KA210HQbd 20.7" 1920x1080 VGA DVI Monitor
Quicklinx: CPFRWS00 Mfr#: UM.LX2EE.001
  • Great visuals
    See clearly with a beautiful Full HD display. Opt for a vivid IPS panel with a 178° wide viewing angle or lightning-quick TN panel to suit your needs. A 1 ms response time reduces ghosting and takes action-packed entertainment to a level.
  • Optimized comfort
    Sit back and get comfortable with Acer ComfyView technology to reduce reflective glare and Blue Light Filter Pro to remove harmful blue light without sacrificing color or brightness. Get a good view with convenient -5° to 15° tilt adjustment.
  • Smart design
    On-screen display buttons are conveniently located on the front of the device for easy access. The KA series is wall-mountable and has space for a Kensington lock for added security.
Acer KA210HQ bd - LED monitor - Full HD (1080p) - 20.7"
LED-backlit LCD monitor - 20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
49.07 cm x 16.4 cm x 38.06 cm
MPR II
Display Type
Diagonal Size
20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
49.07 cm x 16.4 cm x 38.06 cm - with stand
VGA , DVI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
Security Slot Type
Kensington security slot
Power Consumption (Typical)
21.5 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.25 Watt
Dimensions & Weight Details
With stand - width: 49.07 cm - depth: 16.4 cm - height: 38.06 cm , Without stand - width: 49.07 cm - depth: 5.2 cm - height: 29.4 cm
