Acer K650i DLP 1080p LED Home Projector
Quicklinx: CLDNWS00 Mfr#: MR.JMC11.002
Acer K650i - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Stereo speakers
Brightness
1400 ANSI lumens
Contrast Ratio
100000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
RGB LED 203 Watt
Bulb life cycle
Up to 20000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
Video Input
RGB (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
125 Watt
35.5 cm x 23.5 cm x 6.3 cm
2.3 kg
3D Capable
Built-in Devices
Stereo speakers
Projector
Brightness
1400 ANSI lumens
Brightness (Reduced)
1120 ANSI lumens
Contrast Ratio
100000:1
Image Size
104 cm - 762 cm
Projection Distance
1 m - 7.4 m
Throw Ratio
1.11:1
Uniformity
80 %
Digital Zoom Factor
2x
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
144 Hz x 100 kHz
Bulb type
RGB LED 203 Watt
Bulb life cycle
sRGB colour profile, BrilliantColor, SmartFormat Technology, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, Rec. 709 Mode, Quick-Start, ColorBoost 3D Technology, Acer LumiSense+
Lens
Focus Type
Manual
Lens Aperture
F/1.5
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
5 Watt
Speakers
1 x right / left channel
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 (management) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - mini-USB Type B
Carrying case, wireless remote control
1 x VGA cable
Security Features
PIN code
Power Source
AC
AC 120/230 V
125 Watt
Power Consumption Stand by
0.5 Watt
35.5 cm
23.5 cm
6.3 cm
2.3 kg
Sound Emission
29 dBA
25 dBA
