The Acer K335 is also equipped with a SD card reader and a USB port allowing multimedia playback directly from a USB drive or memory card. Plus, with built-in office and PDF document reader support, they can project Office or PDF files without using a PC. Users can watch and share a variety of multimedia contents, including photos, audio and videos without the added burden of a notebook.
- Acer K335 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker, card reader
- Brightness
- 1000 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- LED
- Bulb life cycle
- Up to 20000 hours - normal mode , Up to 30000 hours - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL)
- Supported Memory Cards
- SD Memory Card
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 23.2 cm x 16.6 cm x 4.63 cm
- 1.3 kg
- 2-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
Projector
- Brightness
- 1000 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 76.2 cm - 254 cm
- Projection Distance
- 0.9 m
- Digital Zoom Factor
- 1.7x
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- LED
- Bulb life cycle
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.5
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- SD Memory Card
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 3 Watt
- Speakers
- 1 x mixed channel
- Expansion Slots
- 1 x SD Memory Card
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x composite video/audio input - mini-phone 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable , 1 x composite video cable
- Security Features
- Voltage Required
- AC 120/230 V
- 23.2 cm
- 16.6 cm
- 4.63 cm
- 1.3 kg
- Limited warranty - 2 years - carry-in
