Acer K272HULDbmidpx 27" 2560x1440 4ms DVI HDMI DP Monitor
Quicklinx: CPD6WS00 Mfr#: UM.HX2EE.D01
You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management.
  • Comfortable views
    The display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment.
  • Smart design
    Set the K2 series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
Acer K272HULD - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
56 kWh
Power Consumption (On mode)
40 W
Speaker
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Voltage
MPR II
Display Type
Energy Class
Class B
56 kWh
Diagonal Size
27"
Built-in Devices
Speaker
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Backlight Technology
LED backlight
Audio
Speakers
DVI , HDMI , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+25
1 x DVI cable , 1 x DisplayPort cable
MPR II
Input Voltage
40 W
