Acer K272HULBbmidp 27" 2560x1440 2ms DVI HDMI DisplayPort LED Monitor
Quicklinx: 9T73WS00 Mfr#: UM.HX2EE.B01
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 2ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
£253.10 ex VAT
£303.72 inc VAT
You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management.
  • Comfortable views
    The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment.
  • Smart design
    Set the K2 Series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
  • Environment-friendly
    Safe for you and your world, K2 Series monitors are EPEAT Gold ready, use mercury-free white LED backlighting. Acer EcoDisplay technologies use Arsenic free display glass, further protecting the environment.
Acer K272HUL - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Glossy black
64 cm x 24.9 cm x 46.2 cm
5.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class C
64 kWh
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
Glossy black
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI , HDMI , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x DVI cable , 1 x DisplayPort cable
MPR II
33.5 Watt
Power Consumption Stand by
450 mW
Power Consumption (Off Mode)
350 mW
ENERGY STAR Certified
Acer K272HULBbmidp 27 Bundle deal on Acer K272HULBbmidp 27" 2560x1440 2ms DVI HDMI DisplayPort LED Monitor
£352.27
9T73 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9T73 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.46
9T73 C2G 5m Select High Speed HDMI with Ethernet In Stock £21.57
9T73 C2G 10m Select High Speed HDMI with Ethernet In Stock £41.42
9T73 C2G 15m Select High Speed HDMI with Ethernet In Stock £56.11
Diagonal Size: 27in
Response Time: 2ms
Interfaces: DVI
Interfaces: HDMI
Brand: Acer
Price Range Ex VAT: 150 - 300
