Acer K272HLEbid 27'' 4ms DVI HDMI LED ZeroFrame Monitor
Quicklinx: CDLQWS00 Mfr#: UM.HX3EE.E04
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
£137.07 ex VAT
£164.48 inc VAT
Eco-friendly Acer K2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
Acer K272HLE - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
41 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
3H Hard Coating
Glossy black
64 cm x 23.5 cm x 46.3 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
MPR II, TUV, GS, ISO 9241-307
Display Type
Energy Class
Class C
59 kWh
41 W
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
LED backlight
HDCP, 72% NTSC colour gamut, ComfyView, Zero Frame, Wide Viewing Angle
Glossy black
5 kg
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hours
6 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
Width: 70.6 cm - depth: 48 cm - height: 14.1 cm
ENERGY STAR Certified
Acer K272HLEbid 27'' 4ms DVI HDMI LED ZeroFrame Monitor Bundle deal on Acer K272HLEbid 27'' 4ms DVI HDMI LED ZeroFrame Monitor
£236.83
Accessories (5)
CDLQ StarTech.com Dual Monitor Mount - Stackable In Stock £146.29
CDLQ StarTech.com Cubicle Monitor Hanger In Stock £45.29
CDLQ StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
CDLQ StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
CDLQ StarTech.com Monitor Desk Mount - Steel In Stock £38.53
Other bundles (9)
CDLQ C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.06
CDLQ C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.43
CDLQ C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.11
CDLQ C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £10.95
CDLQ C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
CDLQ C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.66
CDLQ C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £39.49
CDLQ C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.75
CDLQ C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £53.20
Diagonal Size: 27in
Response Time: 4ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
