The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment. -
ComfyView
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods. -
Acer Adaptive Contrast Management
Acer Adaptive Contrast Management (ACM) optimizes contrast to present the highest level of clarity and detail by analyzing every scene, adjusting images frame by frame, and enhancing detail and gradation. In addition, with ACM, the LCD monitor uses less power.
- Acer K272HL - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Energy Consumption per Year
- 43 kWh
- Power Consumption (On mode)
- 26.1 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64 cm x 24.9 cm x 46.2 cm
- 5 kg
- Microsoft Certification
- Compatible with Windows 7
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 43 kWh
- Diagonal Size
- 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Black
- 64 cm x 24.9 cm x 46.2 cm - with stand
- 5 kg
- DVI , VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Cables Included
- 1 x VGA cable
- MPR II
- Input Voltage
- 26.1 W
- Power Consumption SDR (On mode)
- 26.1 kWh/1000h
- Power Consumption (Typical)
- 28.5 Watt
- Power Consumption Stand by
- 0.45 Watt
- Power Consumption Sleep
- 0.35 Watt
- Dimensions & Weight Details
- With stand - width: 64 cm - depth: 24.9 cm - height: 46.2 cm - weight: 5 kg , Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 4.77 kg
- Limited warranty - 2 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
