Product
Acer K242HYLB 23.8" 1920x1080 4ms VGA DVI HDMI LED Monitor
Quicklinx: DB0DWS00 Mfr#: UM.QX2EE.B01
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
£86.19 ex VAT
£103.42 inc VAT
Marketing description is not available.
Acer K242HYL - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
54 cm x 20.7 cm x 40.9 cm
3.9 kg
Czech Republic
MPR II
2 years warranty
Display Type
Energy Class
Class A
31 kWh
21 W
Diagonal Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
54 cm x 20.7 cm x 40.9 cm - with stand
3.9 kg
DVI , VGA , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+25
1 x VGA cable
MPR II
Czech Republic
26 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
No
Limited warranty - 2 years - carry-in
Response Time: 4ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 50 - 100
