The eco-friendly Acer K2 series monitors are an affordable display solution for everyday PC use. They offer a hassle-free experience without compromising image quality. The intelligent design brings together a multitude of connections, superb performance, and eco-friendliness, all at a price point that'll make you smile.
Comfortable views
The display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment. -
Smart design
Set the K2 series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
- Acer K242HQLC - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 39 kWh
- Power Consumption (On mode)
- 27 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2715 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.7 cm x 20.79 cm x 42.12 cm
- 4.24 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 39 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 1 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- HDCP, Acer EcoDisplay, High Frame Rate Control (Hi-FRC), 72% NTSC colour gamut
- Black
- 56.7 cm x 20.79 cm x 42.12 cm - with stand
- 4.24 kg
- DVI (HDCP) , VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- MPR II
- Input Voltage
- 27 W
- Power Consumption SDR (On mode)
- 20 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.45 Watt
- Power Consumption Sleep
- 0.35 Watt
- Dimensions & Weight Details
- With stand - width: 56.7 cm - depth: 20.79 cm - height: 42.12 cm - weight: 4.24 kg , Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm - weight: 3.92 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
