Acer K242HLbid 24" 1920x1080 5ms VGA DVI HDMI Monitor
Quicklinx: CPDHWS00 Mfr#: UM.FX3EE.002
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: DVI, HDMI, VGA (HD-15)
£90.28 ex VAT
£108.33 inc VAT
The Acer K2 series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance.
Acer K242HL - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
56.7 cm x 20.7 cm x 42.19 cm
3.57 kg
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView
56.7 cm x 20.7 cm x 42.19 cm - with stand
3.57 kg
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
MPR II
20.09 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 56.7 cm - depth: 5.2 cm - height: 33.59 cm - weight: 3.1 kg , With stand - width: 56.7 cm - depth: 20.7 cm - height: 42.19 cm - weight: 3.57 kg
ENERGY STAR Certified
Acer K242HLbid 24 Bundle deal on Acer K242HLbid 24" 1920x1080 5ms VGA DVI HDMI Monitor
£191.15
CPDH StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
CPDH StarTech.com Articulating Monitor Arm In Stock £101.86
CPDH StarTech.com Dual Monitor Stand In Stock £69.36
CPDH StarTech.com Cubicle Monitor Hanger In Stock £45.29
CPDH StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
CPDH StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Diagonal Size: 24in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 50 - 100
