Acer K242HLbd 24" Full HD LED DVI VGA W/HDCP Monitor
Quicklinx: 9F6YWS00 Mfr#: um.fw3ee.001
Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor deliv ers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CC FL lamps. In addition, this monitor is mercury-free, ma king it safer for you and the environment.
Acer Adaptive Contrast Management
Acer Adaptive Contrast Management (ACM) optimizes contrast to present the highest level of clarity and detail by analyzing every scene, adjusting images frame by fram e, and enhancing detail and gradation. In addition, with ACM, the LCD monitor uses less power.
ComfyView
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
Acer Eco-Display
As part of our commitment to sustainable operations an d corporate social responsibility, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
Display
  • 24" Screen
  • TN Panel
  • LED Backlight
  • Resolution: 1920 x 1080 @60Hz Full HD
  • Response Time: 5ms
  • Contrast ratio: 100,000,000:1
  • Brightness: 250 cd/m2
  • Viewing angle: 170°/ 160°
  • Display Colours: 16.7m
  • VGA
  • DVI
  • Tilt range: -5° to +25°
  • HDCP Supported
  • Anti-Glare
  • VESA 100 x 100
  • Designed to adapt
    Essential series monitors let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. These monitors are also wall-mountable, giving you clear views with more room.
  • Bright and clear
    Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Very connected
    Collaborating with others is faster and more productive when you have plenty of ports available. Essential series monitors allow you to connect to a wide variety of devices like notebooks and tablets, thanks to DisplayPort, VGA, DVI and HDMI ports.
  • Eco focus
    Essential Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. More than 10% of the material used in these monitors is post-consumer recycled (PCR) plastic, further reducing environmental impact.
Acer K242HLbd - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class F
Energy Consumption per Year
34 kWh
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Glossy black
56.7 cm x 20.68 cm x 42.22 cm
3.57 kg
United Kingdom, Europe, EMEA
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class F
34 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
LED backlight
HDCP, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
Glossy black
56.7 cm x 20.68 cm x 42.22 cm - with stand
3.57 kg
DVI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hours
MPR II
Power Supply
Internal
22 kWh/1000h
Power Consumption (Typical)
6 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
9F6Y C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
