Acer K242HLAbid 24'' 1920x1080 2ms VGA DVI  LED Monitor
Quicklinx: 9DJ0WS00 Mfr#: UM.FW2EE.A01
Essential Series monitors feature Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Acer K242HL - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class F
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Glossy black
56.7 cm x 20.68 cm x 42.22 cm
3.57 kg
EMEA
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class F
34 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, 72% NTSC colour gamut
Glossy black
3.57 kg
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hours
MPR II
EMEA
Power Supply
Internal
Input Voltage
AC 120/230 V
22 W
22 kWh/1000h
Power Consumption (Typical)
20.9 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
9DJ0 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
