Acer K222HQLDbid 21.5" 1920x1080 VGA DVI HDMI Monitor
Quicklinx: CPDJWS00 Mfr#: UM.WX2EE.D05
Essential Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Acer K222HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
19 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V
50.8 cm x 20.68 cm x 39.05 cm
3.1 kg
MPR II, TUV, GS, ISO9241-307
Display Type
Energy Class
Class F
29 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
110
Vertical Viewing Angle
85
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay, ComfyView, 72% NTSC colour gamut
50.8 cm x 20.68 cm x 39.05 cm - with stand
3.1 kg
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Input Voltage
AC 120/230 V
19 W
19 kWh/1000h
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
On / Off Switch
No
