Essential Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
- Acer K222HQL - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 29 kWh
- Power Consumption (On mode)
- 19 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.8 cm x 20.7 cm x 39.05 cm
- 3.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 29 kWh
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Mercury free, 6-bit gamma
- Black
- 50.8 cm x 20.7 cm x 39.05 cm - with stand
- 3.1 kg
Audio
- Speakers
- DVI (HDCP) , VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- MPR II
- Input Voltage
- 19 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 18.1 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 350 mW
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 50.8 cm - depth: 20.7 cm - height: 39.05 cm - weight: 3.1 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 2.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
