The eco-friendly K2 Series value line is a cost effective display solution for everyday PC use, offering ease-of-use without compromising image quality.
Impressive 100 million:1 contrast ratio
The ultra-high contrast ratio is achieved via Adaptive Contrast Management (ACM), ensuring crystal clear viewing.
Fast 5ms Panel Response Time
The quick response time yields immersive graphics and video display
Enjoy the latest HD digital media
K2 Series features Full HD 1080p resolution.
- Product Description: Acer K222HQLbd 21.5" Widescreen Monitor
- Screen Size: LED-backlit LCD monitor - 21.5"
- Aspect Ratio: Widescreen - 16:9
- Native Resolution: FullHD 1920 x 1080 at 60 Hz
- Brightness: 200 cd/m²
- Contrast Ratio: 100000000:1 (dynamic)
- Response Time: 5 ms (grey-to-grey)
- Colour Support: 16.7 Million Colours
- Connectivity: DVI, VGA
- Speakers: No
- HDCP: Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
- Height Adjustable: No
- Vesa Mount: VESA 100 x 100
- Warranty: 2 Year Warranty
Stunning performance
You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to an Full HD resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management. -
Comfortable views
The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment. -
Smart design
Set the K2 Series' display angle to optimize your view with its ergonomic stand that tilts from-5 to 25 degrees.
- Acer K222HQL bd - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 29 kWh
- Power Consumption (On mode)
- 19 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 200 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 50.8 cm x 20.7 cm x 39.1 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- Display Type
- Energy Class
- Class F
- 29 kWh
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- HDCP, Acer Adaptive Contrast Management (ACM), ComfyView
- Black
- DVI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- MPR II
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 19 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 18.1 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 350 mW
- Dimensions & Weight Details
- With stand - width: 50.8 cm - depth: 20.7 cm - height: 39.1 cm , Without stand - width: 50.8 cm - depth: 30.5 cm - height: 5.2 cm
Sustainability Information
- ENERGY STAR Certified
Accessories (5)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.78 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.06 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
Other bundles (1)
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
