The eco-friendly K2 Series value line is a cost effective display solution for everyday PC use, offering ease-of-use without compromising image quality.
Impressive 100 million:1 contrast ratio
The ultra-high contrast ratio is achieved via Adaptive Contrast Management (ACM), ensuring crystal clear viewing.
Fast 5ms Panel Response Time
The quick response time yields immersive graphics and video display
Enjoy the latest HD digital media
K2 Series features Full HD 1080p resolution.
- Product Description: Acer K222HQLbd 21.5" Widescreen Monitor
- Screen Size: LED-backlit LCD monitor - 21.5"
- Aspect Ratio: Widescreen - 16:9
- Native Resolution: FullHD 1920 x 1080 at 60 Hz
- Brightness: 200 cd/m²
- Contrast Ratio: 100000000:1 (dynamic)
- Response Time: 5 ms (grey-to-grey)
- Colour Support: 16.7 Million Colours
- Connectivity: DVI, VGA
- Speakers: No
- HDCP: Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
- Height Adjustable: No
- Vesa Mount: VESA 100 x 100
- Warranty: 2 Year Warranty
Designed to adapt
Essential Series monitors let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. These monitors are also wall-mountable, giving you clear views with more room. -
Bright and clear
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. -
Very connected
Collaborating with others is faster and more productive when you have plenty of ports available. Essential Series monitors allow you to connect to a wide variety of devices. -
Eco focus
Essential Series monitors mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting.
- Acer K222HQL bd - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 29 kWh
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 200 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Tilt
- Black
- 50.8 cm x 20.7 cm x 39.1 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- Display Type
- Energy Class
- Class A
- 29 kWh
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- HDCP, Acer Adaptive Contrast Management (ACM), ComfyView
- Black
- DVI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- MPR II
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V
- 18.1 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 350 mW
- Dimensions & Weight Details
- With stand - width: 50.8 cm - depth: 20.7 cm - height: 39.1 cm , Without stand - width: 50.8 cm - depth: 30.5 cm - height: 5.2 cm
- ENERGY STAR Certified
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£167.70
Accessories (7)
StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount | In Stock | £64.11 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £109.46 |
StarTech.com Articulating Monitor Arm | In Stock | £101.86 |
StarTech.com Dual Monitor Stand | In Stock | £69.36 |
StarTech.com Cubicle Monitor Hanger | In Stock | £45.29 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £50.91 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £72.79 |
Other bundles (6)
C2G 1m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £7.75 |
C2G 2m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £9.08 |
C2G 5m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £16.46 |
C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter | In Stock | £5.00 |
C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter | In Stock | £7.48 |
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £8.43 |
