Acer K202HQLb 19.5" 1600x900 5ms VGA LED Black Monitor
Quicklinx: 9DJ8WS00 Mfr#: UM.IW3EE.001
Diagonal Size: 19.5in
Max Resolution: 1600 x 900
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
More than 50 in stock
£73.10 ex VAT
£87.72 inc VAT
Everyday series monitor gives you the beauty you appreciate and the value you need. It showcases captivating widescreen visuals as well as eco-conscious features, making it perfect for enjoying marvelous multimedia at home or in your office, studio or study.
  • Slim and elegant
    Everyday series monitor saves space and adds elegance to any area.
  • Vivid
    You'll enjoy tasks and entertainment more with fine details and smooth movement, thanks to high resolution, fast response time and superior contrast ratio. Games are more exciting and films truly cinematic when visuals are vibrant. Plus, the widescreen aspect ratio frames movies and HDTV content perfectly.
  • Green
    Safe for you and your world, Everyday series monitor is RoHS compliant, use mercury-free white LED backlighting and meet ENERGY STAR requirements. Acer EcoDisplay technologies deliver up to 68% power savings, further conserving energy and costs.
Acer K202HQLb - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
46.34 cm x 5 cm x 27.62 cm
2.21 kg
United Kingdom, Europe, EMEA
Microsoft Certification
Compatible with Windows 7
MPR II
2 years warranty
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
46.34 cm x 5 cm x 27.62 cm - without stand
2.21 kg
VGA
Mechanical
Tilt
1 x VGA cable
MPR II
AC 120/230 V
13.5 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
Dimensions & Weight Details
With stand - width: 46.34 cm - depth: 19.1 cm - height: 36.23 cm - weight: 2.7 kg , Without stand - width: 46.34 cm - depth: 5 cm - height: 27.62 cm - weight: 2.21 kg
Limited warranty - 2 years - carry-in
Acer K202HQLb 19.5 Bundle deal on Acer K202HQLb 19.5" 1600x900 5ms VGA LED Black Monitor
£166.13
9DJ8 C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.25
9DJ8 C2G VGA to Composite PC-TV Video Adapter In Stock £32.91
Response Time: 5ms
Speakers: None
Brand: Acer
Price Range Ex VAT: 50 - 100
