Acer K138STi WXGA 800 Lumens DLP Projector
Quicklinx: DHQKWS00 Mfr#: MR.JMQ11.002
Acer K138STi - DLP projector - short-throw - portable - 3D - LAN
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Battery (400 mAh)
Brightness
800 ANSI lumens
Contrast Ratio
100000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb type
LED
Bulb life cycle
Up to 20000 hours - normal mode , Up to 30000 hours - economic mode
Video Input
RGB LAN
Speakers
Speaker(s) - integrated
AC 120/230 V
80 Watt
24 cm x 14.7 cm x 5.9 cm
1 kg
3D Capable
Built-in Devices
Battery (400 mAh)
Projector
Brightness
800 ANSI lumens
Contrast Ratio
100000:1 (dynamic)
Image Size
63.5 cm - 254 cm
Projection Distance
0.4 m - 1.7 m
Throw Ratio
0.8:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
LED
Bulb life cycle
DLP 3D Ready, 16:9 aspect ratio support, 4:3 aspect ratio support, DLNA support, Acer ColorSafe II Technology, ColorBoost 3D Technology, Acer LumiSense+
Lens
Focus Type
Manual
Lens Aperture
F/1.9
Keystone Correction Direction
Vertical
Video Input
Analogue video Signal
RGB
Video Interfaces
HDMI, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
Speakers
2 x right / left channel
1 x Mobile High-Definition Link (MHL) / HDMI , 1 x USB - 4 pin USB Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in , 1 x audio line-out , 1 x network - RJ-45
Carrying case, USB wireless network adapter, wireless remote control
Power Source
AC
AC 120/230 V
80 Watt
24 cm
14.7 cm
5.9 cm
1 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
5 °C
Sound Emission
33 dBA
29 dBA
