Acer K137i DLP WXGA 3D 700 Lumens Projector
Quicklinx: BCWGWS00 Mfr#: MR.JKX11.001
Brightness: 700ANSI lumens
Portability: Pocket
28 in stock
£432.00 ex VAT
£518.40 inc VAT
  • Easy to bring
    Your presentations can now fit in a pocket - or your palm. Be PC-free: project your content directly from a plugged-in USB drive, or SD card, or even a smartphone. Show your ideas in HD quality by connecting via HDMI and MHL ports to HD source devices.
  • Crisp and radiant
    Text is crisp and graphics are clear even from far away, thanks to high contrast ratios. Your ideas will pop with the high brightness of LED technology, creating vibrant visuals and delivering consistent color saturation. With Acer ColorSafe technology, those colors retain their natural look even after prolonged projector use.
  • Earth-friendly
    Let your ideas and the planet both blossom. The longer lifespan of the LED lamp saves on replacement costs and combines with the device's Eco mode to ensure a long projector lifetime. The absence of hazardous mercury or halogen gases means safer use, and a fan-less design keeps projector noise to a minimum.
Acer K137i - DLP projector - 3D - Wi-Fi
DLP projector
3D Capable
Yes (3D glasses sold separately)
EMEA
Microdisplay
DMD Chip
Brightness
700 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED
Bulb life cycle
Up to 20000 hours - normal mode , Up to 30000 hours - economic mode
Video Input
Wi-Fi
Supported Memory Cards
microSD
Speakers
Speaker(s) - integrated
AC 120/230 V
90 Watt
18.9 cm x 11.6 cm x 4.1 cm
510 g
DLP projector
3D Capable
EMEA
Projector
Microdisplay
DMD Chip
Brightness
700 lumens
Brightness (Reduced)
560 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
43 cm - 254 cm
Projection Distance
0.6 m - 3.2 m
Uniformity
90 %
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
LED
Bulb life cycle
High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, Auto Power Off, Acer ColorSafe II Technology, MHL compliance, SRS WOW HD technology
Lens
Focus Type
Manual
Lens Aperture
F/2.0
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Video Interfaces
HDMI, MHL
microSD
LAN and Wireless Image Transferring Protocols
Wi-Fi
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
Speakers
2 x right / left channel
1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x - 24 pin universal I/O
Carrying case, USB wireless network adapter, wireless remote control
1 x HDMI cable
GS, FCC, ROSTEST
Nominal Voltage
AC 120/230 V
90 Watt
Power Consumption Stand by
0.5 Watt
18.9 cm
11.6 cm
4.1 cm
510 g
Limited warranty - 2 years - pick-up and return , Limited warranty - DLP chipset - 5 years
5 °C
Sound Emission
31 dBA
29 dBA
BCWG C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BCWG C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.46
BCWG C2G 5m Select High Speed HDMI with Ethernet In Stock £21.57
BCWG C2G 10m Select High Speed HDMI with Ethernet In Stock £41.42
BCWG C2G 15m Select High Speed HDMI with Ethernet In Stock £56.11
Portability: Pocket
Brand: Acer
Price Range Ex VAT: 300 - 500
