Easy to bring
Your presentations can now fit in a pocket - or your palm. Be PC-free: project your content directly from a plugged-in USB drive, or SD card, or even a smartphone. Show your ideas in HD quality by connecting via HDMI and MHL ports to HD source devices. -
Crisp and radiant
Text is crisp and graphics are clear even from far away, thanks to high contrast ratios. Your ideas will pop with the high brightness of LED technology, creating vibrant visuals and delivering consistent color saturation. With Acer ColorSafe technology, those colors retain their natural look even after prolonged projector use. -
Earth-friendly
Let your ideas and the planet both blossom. The longer lifespan of the LED lamp saves on replacement costs and combines with the device's Eco mode to ensure a long projector lifetime. The absence of hazardous mercury or halogen gases means safer use, and a fan-less design keeps projector noise to a minimum.
- Acer K137i - DLP projector - 3D - Wi-Fi
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Localisation
- EMEA
- Microdisplay
- DMD Chip
- Brightness
- 700 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- LED
- Bulb life cycle
- Up to 20000 hours - normal mode , Up to 30000 hours - economic mode
- Video Input
- Wi-Fi
- Supported Memory Cards
- microSD
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 90 Watt
- 18.9 cm x 11.6 cm x 4.1 cm
- 510 g
- 2-year warranty
- DLP projector
- 3D Capable
- Localisation
- EMEA
Projector
- Microdisplay
- DMD Chip
- Brightness
- 700 lumens
- Brightness (Reduced)
- 560 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 43 cm - 254 cm
- Projection Distance
- 0.6 m - 3.2 m
- Uniformity
- 90 %
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- LED
- Bulb life cycle
- High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, Auto Power Off, Acer ColorSafe II Technology, MHL compliance, SRS WOW HD technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.0
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Video Interfaces
- HDMI, MHL
- microSD
- LAN and Wireless Image Transferring Protocols
- Wi-Fi
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 3 Watt
- Speakers
- 2 x right / left channel
- 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x - 24 pin universal I/O
- Included Accessories
- Carrying case, USB wireless network adapter, wireless remote control
- Cables Included
- 1 x HDMI cable
- GS, FCC, ROSTEST
- Voltage Required
- AC 120/230 V
- 90 Watt
- Power Consumption Stand by
- 0.5 Watt
- 18.9 cm
- 11.6 cm
- 4.1 cm
- 510 g
- Limited warranty - 2 years - pick-up and return , Limited warranty - DLP chipset - 5 years
- 5 °C
- 40 °C
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 29 dBA
