Acer Iconia Talk S 7" Mediatek MT8382 1GB 16GB Android
Quicklinx: BCWMWS00 Mfr#: NT.L7ZEE.004
  • Android 4.4 (KitKat)
With its 7-inch display, voice-call functionalities, and microSD support, this device seamlessly expands the existing product line of Acer tablets.
  • Balanced dual world
    Its large screen makes it a tablet that is pleasant to use, while the voice-calling features allows it to be used as a phone, eliminating the hassle of having to rely on two devices and constantly switching between the two. The slim, narrow body and light weight make the tablet pocketable and provide a comfortable one-handed experience just like those usually enabled by smartphones. Finally, thanks to its Dual SIM slot, the Iconia Talk S lets users simultaneously access different networks with only one device for more flexibility and cost-effectiveness. This feature is especially convenient for those who are often split between two worlds: frequent travelers, for example, will be able to use their home and local SIM cards, cutting roaming costs and remaining more accessible while on the road, while busy professionals can keep up with their personal and work lives at the same time.
  • Blazing fast connectivity
    With its high speed the Iconia Talk S with 4G LTE connectivity ensures users will get the fastest browsing and streaming experience available on the market. This is guaranteed thanks to the Qualcomm Snapdragon quad-core processor built-into this tablet. This processor, especially designed for 4G LTE devices, delivers fast data, quick network response times and smooth connection to multiple networks. Additionally, it ensures battery efficiency and secures up to 300 hours of standby time. 3G connectivity is also available on the Iconia Talk S, securing seamless voice calls that allow the tablet's owner to stay in touch with friends, family and loved ones at all times.
  • Fantastic visuals
    Fast communication is not the only asset of the Iconia Talk S: securing breathtaking visuals was also one of Acer's main focus points when developing this product. With its beautiful 7-inch HD IPS panel, built-in Zero Air Gap technology and Anti Fingerprint coating, the Iconia Talk S promises a fantastic viewing experience, both when used indoors and outside. Furthermore, the design of the device itself is optimized for an immersive viewing experience: thanks to the very narrow display bezel (5.9mm on each side), the screen-to-body ratio is significantly higher than that of other 7-inch tablets on the market, making it easier for the eye to focus on visuals without being distracted by the frame.
Acer ICONIA Talk S A1-724-Q8WH - tablet - Android 4.4 (KitKat) - 16 GB - 7" - 4G
Tablet
Operating System
Display
7" IPS TFT - LED backlight - 1280 x 720 - Multi-Touch
Qualcomm Snapdragon 410 MSM8916 (Quad-Core) - 64-bit
Processor Clock Speed
1.4 GHz
Storage
16 GB eMMC
RAM
1 GB
Cellular Technology
4G
Cellular Protocols
GSM, GPRS, UMTS, EDGE, HSPA+, LTE
Wireless Connectivity
802.11b/g/n, Bluetooth 4.0
Rear Camera
5 Megapixel
Front Camera
2 Megapixel
Navigation System
GPS
USB host
Battery Run Time
Up to 12 hours
9.98 cm x 0.85 cm x 19 cm
275 g
Black, blue
United Kingdom
Tablet
Operating System
Display
Resolution
1280 x 720
Touchscreen
Multi-Touch
Glare, CineCrystal, anti-fingerprint, Wide Viewing Angle
1.4 GHz
Number of Cores
Quad-Core
64-bit Computing
Storage
16 GB eMMC
RAM
1 GB - LPDDR2 SDRAM
Communications
Cellular Technology
4G
Cellular Protocols
Rear Camera
Sensor Resolution
5 Megapixel
Still Image Resolutions
1600 x 1200, 2560 x 1920
Front Camera
Sensor Resolution
2 Megapixel
Navigation System
Receiver
GPS
Multimedia
Graphics
Qualcomm ADRENO 306
Audio
Two microphones, speaker
Expansion and Connectivity
Expansion Slots
2 x Mini-SIM card
1 x Micro-USB
USB Host
Lithium polymer
14.36 Wh
Run Time
Up to 12 hours
Run Time Details
Video playback: up to 12 hours
Black, blue
Sensors
Proximity sensor, digital compass, G-sensor
Volume control, Zero Air Gap technology
Power adapter, headset
RoHS, WEEE
United Kingdom
9.98 cm
0.85 cm
19 cm
275 g
