The Iconia One 8 has all the stuff you need to get into the tablet game. With a large, clear and colorful display, speedy response and hours of battery to go on, it's fun for all.
Room for a view
The Iconia One 8 fun begins with a nice big 8-inch HD screen. Acer makes the screen bright, vividly colorful and easy to see from almost any angle by using IPS technology. It's easy to use too, with 10-finger touch support for multi-finger gestures. -
Smooth and speedy
To really have fun with a tablet it needs to be speedy and smooth so your web browsing, gaming and videos are fluid and responsive. Acer packed a very capable quad-core processor and display chip into the Iconia One 8 so that's just what you get. -
Centered on kids
The Iconia One 8 also comes with Acer's Kids Center that provides a simple child-friendly interface and appropriate kid-centric content. It also has password-protected parental controls to control accounts, content and daily use limits. -
Goes and goes
With all the fun you can have with Iconia One 8, it's a good thing it comes with a very capable battery. You can get up to nine hours of use from one charge, which means you can definitely get in a lot of everything everybody wants to do. -
Space to expand
The Iconia One 8 already comes with a nice amount of storage, but sometimes you just want more. The built-in Micro SD card slot can take cards up to 128 GB - more than enough for all that extra stuff, whether it's books, movies, music or whatever.
- Acer ICONIA ONE 8 B1-850-K143 - tablet - Android 5.1 (Lollipop) - 16 GB - 8"
- Product Type
- Tablet
- Operating System
- Display
- 8" IPS TFT - LED backlight - 1280 x 800 - Multi-Touch
- Processor
- MediaTek MT8163 (Quad-Core)
- Processor Clock Speed
- 1.3 GHz
- Storage
- 16 GB eMMC
- RAM
- 1 GB
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 4.0
- Rear Camera
- 5 Megapixel focus: automatic, focus free
- Front Camera
- 2 Megapixel
- Navigation System
- GPS
- Battery Run Time
- Up to 9 hours
- 12.625 cm x 0.905 cm x 21.07 cm
- 340 g
- White
- Localisation
- United Kingdom
- Product Type
- Tablet
- Operating System
Display
- Resolution
- 1280 x 800
- Touchscreen
- Multi-Touch
- Image Brightness
- 300 cd/m²
- Glare, CineCrystal, 10-point multi-touch, Wide Viewing Angle
- Processor
- MediaTek MT8163
- 1.3 GHz
- Number of Cores
- Quad-Core
- Storage
- 16 GB eMMC
- RAM
- 1 GB - DDR3L SDRAM
- Max Supported Capacity
- 128 GB
Communications
Rear Camera
- Sensor Resolution
- 5 Megapixel
- Focus Adjustment
- Automatic, focus free
Front Camera
- Sensor Resolution
- 2 Megapixel
Navigation System
- Receiver
- GPS
Multimedia
- Graphics
- Mali T720 MP2
- Audio
- Microphone, speaker
Expansion and Connectivity
- Expansion Slots
- 1 x microSDXC
- 1 x Micro-USB , 1 x headphones mini jack (3.5mm)
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Technology
- Lithium polymer
- Capacity
- 17.5 Wh
- Run Time
- Up to 9 hours
- White
- Volume control, MediaTek MT6323L chipset
- Included Accessories
- Power adapter
- Localisation
- United Kingdom
- 12.625 cm
- 0.905 cm
- 21.07 cm
- 340 g
