Acer Iconia One 8 (B1-850)
Quicklinx: CLGCWS00 Mfr#: NT.LC3EK.001
The Iconia One 8 has all the stuff you need to get into the tablet game. With a large, clear and colorful display, speedy response and hours of battery to go on, it's fun for all.
  • Room for a view
    The Iconia One 8 fun begins with a nice big 8-inch HD screen. Acer makes the screen bright, vividly colorful and easy to see from almost any angle by using IPS technology. It's easy to use too, with 10-finger touch support for multi-finger gestures.
  • Smooth and speedy
    To really have fun with a tablet it needs to be speedy and smooth so your web browsing, gaming and videos are fluid and responsive. Acer packed a very capable quad-core processor and display chip into the Iconia One 8 so that's just what you get.
  • Centered on kids
    The Iconia One 8 also comes with Acer's Kids Center that provides a simple child-friendly interface and appropriate kid-centric content. It also has password-protected parental controls to control accounts, content and daily use limits.
  • Goes and goes
    With all the fun you can have with Iconia One 8, it's a good thing it comes with a very capable battery. You can get up to nine hours of use from one charge, which means you can definitely get in a lot of everything everybody wants to do.
  • Space to expand
    The Iconia One 8 already comes with a nice amount of storage, but sometimes you just want more. The built-in Micro SD card slot can take cards up to 128 GB - more than enough for all that extra stuff, whether it's books, movies, music or whatever.
Acer ICONIA ONE 8 B1-850-K143 - tablet - Android 5.1 (Lollipop) - 16 GB - 8"
Tablet
Operating System
Display
8" IPS TFT - LED backlight - 1280 x 800 - Multi-Touch
MediaTek MT8163 (Quad-Core)
Processor Clock Speed
1.3 GHz
Storage
16 GB eMMC
RAM
1 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.0
Rear Camera
5 Megapixel focus: automatic, focus free
Front Camera
2 Megapixel
Navigation System
GPS
Battery Run Time
Up to 9 hours
12.625 cm x 0.905 cm x 21.07 cm
340 g
White
United Kingdom
Tablet
Operating System
Display
Resolution
1280 x 800
Touchscreen
Multi-Touch
Image Brightness
300 cd/m²
Glare, CineCrystal, 10-point multi-touch, Wide Viewing Angle
MediaTek MT8163
1.3 GHz
Number of Cores
Quad-Core
Storage
16 GB eMMC
RAM
1 GB - DDR3L SDRAM
Max Supported Capacity
128 GB
Communications
Rear Camera
Sensor Resolution
5 Megapixel
Focus Adjustment
Automatic, focus free
Front Camera
Sensor Resolution
2 Megapixel
Navigation System
Receiver
GPS
Multimedia
Graphics
Mali T720 MP2
Audio
Microphone, speaker
Expansion and Connectivity
Expansion Slots
1 x microSDXC
1 x Micro-USB , 1 x headphones mini jack (3.5mm)
Lithium polymer
17.5 Wh
Run Time
Up to 9 hours
White
Volume control, MediaTek MT6323L chipset
Power adapter
United Kingdom
12.625 cm
0.905 cm
21.07 cm
340 g
