Acer Iconia One 7 B1-790 Quad Core 1GB 16GB Android - White
Quicklinx: DDWZWS00 Mfr#: NT.LDYEK.001
The Iconia One 7 is ready to travel the world. Its clean design was made to see and be seen. Its light, narrow case is easy to hold all day long. Its beautiful textured finish makes it easy to grab and go. It's always ready to capture and share your adventures.
  • Design to be seen
  • Visuals to delight
    The Iconia One 7 knows there's a difference between watching and experiencing. After immersing yourself in the exciting experience of its smooth Intel processor and sharp HD display with IPS technology, you'll never go back to only watching your world again.
  • Moments to be shared
    Your stories should have no limits. Keep your greatest moments close to you with the Iconia One 7's micro SD card slot, or easily share them with the world. Memories stay sharp when you can access them anywhere, anytime through AcerCloud.
  • Memories to capture
    Capture and share the memorable moments in life. Smile at the front camera as you take a selfie or share some laughs with a friend in a video chat. When you spot something amazing on one of your adventures, snap a photo with the rear camera and share it on a social network.
Acer ICONIA ONE 7 B1-790-K732 - tablet - Android 6.0 (Marshmallow) - 16 GB - 7"
Tablet
Operating System
Display
7" IPS TFT - LED backlight - 1280 x 720 - Multi-Touch
MediaTek MT8163V/B (Quad-Core) - 64-bit
Processor Clock Speed
1.3 GHz
Storage
16 GB eMMC
RAM
1 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.0
Rear Camera
2 Megapixel
Front Camera
0.3 Megapixel
USB host
Battery Run Time
Up to 6 hours
10.24 cm x 0.94 cm x 19.31 cm
270 g
White
United Kingdom
Tablet
Operating System
Display
Resolution
1280 x 720
Touchscreen
Multi-Touch
Image Brightness
350 cd/m²
Glare, CineCrystal, 30 ms response rate
MediaTek MT8163V/B
1.3 GHz
Number of Cores
Quad-Core
64-bit Computing
Storage
16 GB eMMC
RAM
1 GB - DDR3L SDRAM
Max Supported Capacity
128 GB
Communications
Rear Camera
Sensor Resolution
2 Megapixel
Still Image Resolutions
640 x 480, 1600 x 1200
Front Camera
Sensor Resolution
0.3 Megapixel
Multimedia
Graphics
Mali T720 MP2
Audio
Microphone, speaker
Expansion and Connectivity
Expansion Slots
1 x microSDXC
1 x Micro-USB , 1 x headset mini jack (3.5mm)
USB Host
Lithium polymer
10.28 Wh
Run Time
Up to 6 hours
White
Sensors
Accelerometer
Power adapter
United Kingdom
10.24 cm
0.94 cm
19.31 cm
270 g
