Acer Iconia One 7 B1-750 Intel Atom Quad Core Z3735 1GB 16GB 7" Android 4.4 - Black
Quicklinx: 9ZZ5WS00 Mfr#: NT.L65EE.001
  • Atom
  • Android 4.4 (KitKat)
The Iconia One 7 is ready to travel the world. Its clean design was made to see and be seen. Its light, narrow case is easy to hold all day long. Its beautiful textured finish makes it easy to grab and go. It's always ready to capture and share your adventures.
Portable charm - with a bevy of trendy, eye catching colours to suit any lifestyle and show your personality, this slim and lightweight tablet is designed to be travel-friendly. Plus its beautifully textured anti-slip finish helps you keep a firm grip wherever you go
Sharp visuals - the HD LCD display brings out every detail of the display from any angle. Put that together with Zero Air Gap technology and you get brighter and crisper images with higher contrast and considerably better visibility in sunlight
Exciting power - designed to give you all the get up you need to go, with Intel quad-core performance for games, videos and web browsing. You get an additional boost from the improved performance of Android 4.4, and up to 7 hours of battery life
An enhanced user experience - a highly-effective anti-fingerprint coating reduces messy fingerprints and smudges, and makes the screen much easier to clean. Add to that Acer's innovative Touch WakeApp which adds new one-touch gestures to both wake the tablet up and pop it right into whatever app you want instant access to
  • Design to be seen
  • Visuals to delight
    The Iconia One 7 knows there's a difference between watching and experiencing. After immersing yourself in the exciting experience of its smooth Intel processor and sharp HD display with IPS technology, you'll never go back to only watching your world again.
  • Moments to be shared
    Your stories should have no limits. Keep your greatest moments close to you with the Iconia One 7's micro SD card slot, or easily share them with the world. Memories stay sharp when you can access them anywhere, anytime through AcerCloud.
  • Memories to capture
    Capture and share the memorable moments in life. Smile at the front camera as you take a selfie or share some laughs with a friend in a video chat. When you spot something amazing on one of your adventures, snap a photo with the rear camera and share it on a social network.
Acer ICONIA ONE 7 B1-750-19F7 - tablet - Android 4.4 (KitKat) - 16 GB - 7"
Tablet
Operating System
Display
7" IPS TFT - LED backlight - 1280 x 800 - Multi-Touch
Intel Atom Z3735G (Quad-Core) - 64-bit
Processor Clock Speed
1.83 GHz
Storage
16 GB eMMC
RAM
1 GB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11b/g/n, Bluetooth 4.0
Rear Camera
5 Megapixel
Front Camera
0.3 Megapixel
Navigation System
GPS/GLONASS
USB host
11.4 cm x 0.86 cm x 19.3 cm
320 g
United Kingdom
Tablet
Operating System
Display
Resolution
1280 x 800
Touchscreen
Multi-Touch
Glare, CineCrystal, Wide Viewing Angle
Intel Atom Z3735G
1.83 GHz
Number of Cores
Quad-Core
64-bit Computing
Storage
16 GB eMMC
RAM
1 GB - DDR3L SDRAM
microSD, microSDHC
Max Supported Capacity
32 GB
Communications
Rear Camera
Sensor Resolution
5 Megapixel
Still Image Resolutions
640 x 480, 2592 x 1944
Front Camera
Sensor Resolution
0.3 Megapixel
Navigation System
Receiver
GPS/GLONASS
Multimedia
Graphics
Intel HD Graphics
Audio
Microphone, stereo speakers
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x Micro-USB , 1 x headset mini jack (3.5mm)
USB Host
Lithium polymer
3420 mAh
Sensors
G-sensor
Volume control, Zero Air Gap technology
Power adapter
RoHS, WEEE
United Kingdom
11.4 cm
0.86 cm
19.3 cm
320 g
