Acer Iconia One 7 16GB Android 5.0
Quicklinx: BZWDWS00 Mfr#: NT.LB1EE.001
  • Android 5.0 (Lollipop)
The Iconia One 7 is ready to travel the world. Its clean design was made to see and be seen. Its light, narrow case is easy to hold all day long. Its beautiful textured finish makes it easy to grab and go. It's always ready to capture and share your adventures.
  • Design to be seen
  • Visuals to delight
    The Iconia One 7 knows there's a difference between watching and experiencing. After immersing yourself in the exciting experience of its smooth Intel processor and sharp HD display with IPS technology, you'll never go back to only watching your world again.
  • Moments to be shared
    Your stories should have no limits. Keep your greatest moments close to you with the Iconia One 7's micro SD card slot, or easily share them with the world. Memories stay sharp when you can access them anywhere, anytime through AcerCloud.
  • Memories to capture
    Capture and share the memorable moments in life. Smile at the front camera as you take a selfie or share some laughs with a friend in a video chat. When you spot something amazing on one of your adventures, snap a photo with the rear camera and share it on a social network.
Acer ICONIA ONE 7 B1-760HD-K648 - tablet - Android 5.0 (Lollipop) - 16 GB - 7"
Tablet
Operating System
Display
7" IPS TFT - LED backlight - 1280 x 720 - Multi-Touch
MediaTek MT8127 (Quad-Core)
Processor Clock Speed
1.3 GHz
Storage
16 GB
RAM
1 GB
Supported Flash Memory Cards
microSD
Wireless Connectivity
Bluetooth, 802.11b/g/n
Rear Camera
2 Megapixel
Front Camera
0.3 Megapixel
10.7 cm x 0.99 cm x 19.3 cm
298 g
Nordics
Tablet
Operating System
Display
Resolution
1280 x 720
Touchscreen
Multi-Touch
Glare, CineCrystal
MediaTek MT8127
1.3 GHz
Number of Cores
Quad-Core
Storage
16 GB
RAM
1 GB - DDR3L SDRAM
microSD
Communications
Rear Camera
Sensor Resolution
2 Megapixel
Front Camera
Sensor Resolution
0.3 Megapixel
Multimedia
Audio
Microphone
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x Micro-USB , 1 x headphones
Lithium polymer
3420 mAh
Volume control
Power adapter
Nordics
10.7 cm
0.99 cm
19.3 cm
298 g
