The Iconia One 7 is ready to travel the world. Its clean design was made to see and be seen. Its light, narrow case is easy to hold all day long. Its beautiful textured finish makes it easy to grab and go. It's always ready to capture and share your adventures.
Design to be seen
The Iconia One 7 is ready to travel the world. Its clean design was made to see and be seen. Its light, narrow case is easy to hold all day long. Its beautiful textured finish makes it easy to grab and go. It's always ready to capture and share your adventures. -
Visuals to delight
The Iconia One 7 knows there's a difference between watching and experiencing. After immersing yourself in the exciting experience of its smooth Intel processor and sharp HD display with IPS technology, you'll never go back to only watching your world again. -
Moments to be shared
Your stories should have no limits. Keep your greatest moments close to you with the Iconia One 7's micro SD card slot, or easily share them with the world. Memories stay sharp when you can access them anywhere, anytime through AcerCloud. -
Memories to capture
Capture and share the memorable moments in life. Smile at the front camera as you take a selfie or share some laughs with a friend in a video chat. When you spot something amazing on one of your adventures, snap a photo with the rear camera and share it on a social network.
- Acer ICONIA ONE 7 B1-760HD-K648 - tablet - Android 5.0 (Lollipop) - 16 GB - 7"
- Product Type
- Tablet
- Operating System
- Display
- 7" IPS TFT - LED backlight - 1280 x 720 - Multi-Touch
- Processor
- MediaTek MT8127 (Quad-Core)
- Processor Clock Speed
- 1.3 GHz
- Storage
- 16 GB
- RAM
- 1 GB
- Supported Flash Memory Cards
- microSD
- Wireless Connectivity
- Bluetooth, 802.11b/g/n
- Rear Camera
- 2 Megapixel
- Front Camera
- 0.3 Megapixel
- 10.7 cm x 0.99 cm x 19.3 cm
- 298 g
- Black
- Localisation
- Nordics
- Product Type
- Tablet
- Operating System
Display
- Resolution
- 1280 x 720
- Touchscreen
- Multi-Touch
- Glare, CineCrystal
- Processor
- MediaTek MT8127
- 1.3 GHz
- Number of Cores
- Quad-Core
- Storage
- 16 GB
- RAM
- 1 GB - DDR3L SDRAM
- microSD
Communications
Rear Camera
- Sensor Resolution
- 2 Megapixel
Front Camera
- Sensor Resolution
- 0.3 Megapixel
Multimedia
- Audio
- Microphone
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x Micro-USB , 1 x headphones
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Technology
- Lithium polymer
- Capacity
- 3420 mAh
- Black
- Volume control
- Included Accessories
- Power adapter
- Localisation
- Nordics
- 10.7 cm
- 0.99 cm
- 19.3 cm
- 298 g
