Enjoy superb videos, browsing and games on a great 10.1" screen. Everything happens quickly and smoothly thanks to a powerful processor. Plus, this tablet's enhanced touchscreen sensitivity lets you tap, sketch and write with awesome precision.
Fast performance
A powerful processor works with the performance-boosting features to make all your tablet actions fast and smooth. -
Smart, clutter-free design
The speakers and all cable ports are placed on the same edge. This means the speakers and all connected cables will always be out of your way when you hold the tablet horizontally. No more fumbling around cables and speakers with your hands!
- Acer ICONIA ONE 10 B3-A30-K7D6 - tablet - Android 6.0 (Marshmallow) - 16 GB - 10.1"
- Product Type
- Tablet
- Operating System
- Display
- 10.1" IPS TFT - LED backlight - 1280 x 800 - Multi-Touch
- Processor
- MediaTek MT8163 (Quad-Core) - 64-bit
- Processor Clock Speed
- 1.3 GHz
- Storage
- 16 GB eMMC
- RAM
- 1 GB
- Supported Flash Memory Cards
- microSD, microSDXC
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 4.0
- Rear Camera
- 5 Megapixel
- Front Camera
- 2 Megapixel
- Navigation System
- GPS
- USB host
- Battery Run Time
- Up to 10 hours
- 16.75 cm x 0.915 cm x 25.9 cm
- 520 g
- White
- Localisation
- Nordics
- 1-year warranty
- Product Type
- Tablet
- Operating System
Display
- Resolution
- 1280 x 800
- Touchscreen
- Multi-Touch
- 10-point multi-touch
- Processor
- MediaTek MT8163
- 1.3 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- Storage
- 16 GB eMMC
- RAM
- 1 GB - DDR3L SDRAM
- Max Supported Capacity
- 128 GB
Communications
Rear Camera
- Sensor Resolution
- 5 Megapixel
Front Camera
- Sensor Resolution
- 2 Megapixel
Navigation System
- Receiver
- GPS
Multimedia
- Graphics
- Mali T720 MP2
- Audio
- Microphone, stereo speakers
Expansion and Connectivity
- Expansion Slots
- 1 x microSDXC
- 1 x Micro-USB , 1 x headphones mini jack (3.5mm)
- USB Host
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Technology
- Lithium polymer
- Capacity
- 22.4 Wh
- Run Time
- Up to 10 hours
- White
- Sensors
- G-sensor
- Volume control
- Included Accessories
- Power adapter
- RoHS, WEEE
- Localisation
- Nordics
- 16.75 cm
- 0.915 cm
- 25.9 cm
- 520 g
- Traveller warranty - 1 year
