Acer Iconia One 10 B3-A40 Quad Core 2GB 32GB Android - White
Quicklinx: DDX3WS00 Mfr#: NT.LDPEK.001
The convenience of a tablet with the upgraded OS, easily accessible features, and extra-long battery life that give you unprecedented control of your device.
  • Dual port solutions
    Link up to your favorite peripherals with the strategically placed dual micro USB ports.
  • Get a grip
    Hold your Iconia One 10 without fear as your fingers grip the specially textured rear surface.
  • Upgraded OS
    Enjoy a new user experience with the expanded features and advanced functionality of the Android 7.0.
  • All-day battery
    With a battery life of up to 10 hours, your device is designed to stay at your side for the entirety of the day.
  • The evolution of access
    Get more intuitive access to quickly and easily adjust smart functions and settings on your tablet.
Acer ICONIA ONE 10 B3-A40-K8T6 - tablet - Android 7.0 (Nougat) - 32 GB - 10.1"
Tablet
Operating System
Display
10.1" IPS TFT - LED backlight - 1280 x 800 - Multi-Touch
MediaTek MT8167B (Quad-Core) - 64-bit
Processor Clock Speed
1.3 GHz
Storage
32 GB eMMC
RAM
2 GB
Supported Flash Memory Cards
microSD, microSDXC
Wireless Connectivity
Bluetooth 4.0, 802.11a/b/g/n/ac
Rear Camera
5 Megapixel
Front Camera
2 Megapixel
Navigation System
GPS/GLONASS
USB host
Battery Run Time
Up to 10 hours
16.715 cm x 0.915 cm x 25.8 cm
530 g
White
United Kingdom
Tablet
Operating System
Display
Resolution
1280 x 800
Touchscreen
Multi-Touch
Image Aspect Ratio
16:10
Image Brightness
280 cd/m²
Glare, CineCrystal, 10-point multi-touch, Wide Viewing Angle
MediaTek MT8167B
1.3 GHz
Number of Cores
Quad-Core
64-bit Computing
Storage
32 GB eMMC
RAM
2 GB - DDR3L SDRAM
microSD, microSDXC
Max Supported Capacity
128 GB
Communications
Rear Camera
Sensor Resolution
5 Megapixel
Still Image Resolutions
1600 x 1200, 2560 x 1920
Front Camera
Sensor Resolution
2 Megapixel
Navigation System
Receiver
GPS/GLONASS
Multimedia
Graphics
IMG PowerVR GE8300
Audio
Microphone, stereo speakers
Expansion and Connectivity
Expansion Slots
1 x microSDXC
2 x Micro-USB , 1 x headphones mini jack (3.5mm)
USB Host
Lithium polymer
22.4 Wh
Run Time
Up to 10 hours
White
Sensors
G-sensor
Volume control, rotation lock, reset button
Power adapter
United Kingdom
16.715 cm
0.915 cm
25.8 cm
530 g
