The Iconia B1 has a silky, non-slip finish that feels great in your hand. Sporting a 7" display, with a narrow bezel and width, this tablet is easy to carry and comfortable to view.
Get into movies. Rock out! The Iconia B1's front-facing speaker puts out bold sound. Match that with the front-positioned microphone, which enhances voice recognition, and you're in for crisp video calls too.
Slimmer and sleeker
The Iconia B1 has a silky, non-slip finish that feels great in your hand. Sporting a 7" display, with a narrow bezel and width, this tablet is easy to carry and comfortable to view. -
Nicer sound
Get into movies. Rock out! The Iconia B1's front-facing speaker puts out bold sound. Match that with the front-positioned microphone, which enhances voice recognition, and you're in for crisp video calls too. -
Brighter display
The Iconia B1's display incorporates a One Glass Solution (OGS) that creates a thinner, lighter design with clearer visuals. -
Better touch
The Iconia B1 screen supports 10-point touch so you can interact better with today's hottest games and apps. -
More power
A powerful dual-core processor runs games, browsing and videos really quick on the Iconia B1. In fact, the B1 speeds stuff along up to 1.4x faster than its predecessor, and its battery life is 40% longer too.
- Acer ICONIA B1-720-81111G01nkr - tablet - Android 4.2 (Jelly Bean) - 16 GB - 7"
- Product Type
- Tablet
- Operating System
- Display
- 7" TFT - LED backlight - 1024 x 600 - Multi-Touch
- Processor
- MediaTek MT8111 (Dual-Core)
- Processor Clock Speed
- 1.3 GHz
- Storage
- 16 GB
- RAM
- 1 GB
- Supported Flash Memory Cards
- microSD, microSDHC
- Wireless Connectivity
- 802.11b/g/n, Bluetooth 4.0
- Front Camera
- 0.3 Megapixel
- USB host
- Battery Run Time
- Up to 5 hours
- 12.23 cm x 1.07 cm x 19.9 cm
- 315 g
- Black, red
- Localisation
- United Kingdom
- Product Type
- Tablet
- Operating System
Display
- Resolution
- 1024 x 600
- Touchscreen
- Multi-Touch
- CineCrystal
- Processor
- MediaTek MT8111
- 1.3 GHz
- Number of Cores
- Dual-Core
- Storage
- 16 GB
- RAM
- 1 GB - DDR3L SDRAM
- Max Supported Capacity
- 32 GB
Communications
Rear Camera
- Still Image Resolutions
- 640 x 480
Front Camera
- Sensor Resolution
- 0.3 Megapixel
Multimedia
- Graphics
- Mali 400 MP2
- Audio
- Microphone, speaker
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x Micro-USB
- USB Host
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Technology
- Lithium polymer
- Capacity
- 11.2 Wh
- Run Time
- Up to 5 hours
- Black, red
- Sensors
- G-sensor
- Included Accessories
- Power adapter
- RoHS, WEEE
- Localisation
- United Kingdom
- 12.23 cm
- 1.07 cm
- 19.9 cm
- 315 g
