Show movies on a mammoth scale in a billion colors and astonishing clarity. Make your living room your personal multiplex with Acer home series projectors, and leave behind the ordinary in entertainment for a cinematic experience that is truly awesome.
Movie-quality projection
Enjoy movies at home with Full HD 1080p resolution and an ultra-high contrast ratio. AcuMotion makes fast-moving scenes clearer by reducing motion blur. Plus, Acer ColorBoost II+ and ColorSafe II technologies work together to present richer details, smoother gradation, and brighter natural colors, while preserving the color integrity of images. -
Ease-of-use for home
Lens shift control wheels enable perfect picture positioning without moving the projector. Smart detection finds input signals as soon as a source is connected, so you spend less time waiting. And don't worry about compatibility, as multiple screen resolutions and aspect ratios are supported. -
Living-room performance
The H9 series has many connectivity options, including two HDMI, DVI and VGA D-Sub ports, for input flexibility and instant source switching. Also, these projectors enable "keystone correction" by up to 15 degrees, ensuring you'll always see a proper rectangular image.
- Acer H9505BD - DLP projector - 3D - LAN
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses included)
- Microdisplay
- DarkChip 2
- Brightness
- 3000 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- P-VIP 280 Watt
- Bulb life cycle
- Up to 3000 hours - normal mode , Up to 5000 hours - economic mode
- Video Input
- RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V
- 337 Watt
- 39.8 cm x 31 cm x 13 cm
- 7 kg
- 2-year warranty
- 3D Capable
Projector
- Microdisplay
- DarkChip 2
- Brightness
- 3000 lumens
- Brightness (Reduced)
- 2400 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 50.8 cm - 762 cm
- Projection Distance
- 1 m - 10 m
- Throw Ratio
- 1.5 - 2.28:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 144 Hz x 100 kHz
- Bulb type
- P-VIP 280 Watt
- Bulb life cycle
- Wall colour correction, ColorBoost II+ Technology, DLP 3D Ready, SmartFormat Technology, EcoProjection Technology, 4:3 aspect ratio support, 2D to 3D Conversion, Acer ColorSafe II Technology, SpectraBoost
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.45-2.9
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Internal
- Sound Output Mode
- Stereo
- Output Power / Channel
- 3 Watt
- 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x component video input - RCA x 3 , 3 x HDMI input - 19 pin HDMI Type A , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 , 1 x network - RJ-45 , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x VGA cable , 1 x composite video cable , 1 x component video cable
- Security Features
- GS, FCC, ROSTEST
- Voltage Required
- AC 120/230 V
- 337 Watt
- Power Consumption Stand by
- 0.5 Watt
- 39.8 cm
- 31 cm
- 13 cm
- 7 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 30 dBA
- Sound Emission (Economic Mode)
- 27 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
