Acer H9505BD 1080p DLP 3000 Lumens Projector
Quicklinx: 9JQHWS00 Mfr#: MR.JH411.001
Show movies on a mammoth scale in a billion colors and astonishing clarity. Make your living room your personal multiplex with Acer home series projectors, and leave behind the ordinary in entertainment for a cinematic experience that is truly awesome.
  • Movie-quality projection
    Enjoy movies at home with Full HD 1080p resolution and an ultra-high contrast ratio. AcuMotion makes fast-moving scenes clearer by reducing motion blur. Plus, Acer ColorBoost II+ and ColorSafe II technologies work together to present richer details, smoother gradation, and brighter natural colors, while preserving the color integrity of images.
  • Ease-of-use for home
    Lens shift control wheels enable perfect picture positioning without moving the projector. Smart detection finds input signals as soon as a source is connected, so you spend less time waiting. And don't worry about compatibility, as multiple screen resolutions and aspect ratios are supported.
  • Living-room performance
    The H9 series has many connectivity options, including two HDMI, DVI and VGA D-Sub ports, for input flexibility and instant source switching. Also, these projectors enable "keystone correction" by up to 15 degrees, ensuring you'll always see a proper rectangular image.
Acer H9505BD - DLP projector - 3D - LAN
DLP projector - 1080p
3D Capable
Yes (3D glasses included)
Microdisplay
DarkChip 2
Brightness
3000 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
P-VIP 280 Watt
Bulb life cycle
Up to 3000 hours - normal mode , Up to 5000 hours - economic mode
Video Input
RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
AC 120/230 V
337 Watt
39.8 cm x 31 cm x 13 cm
7 kg
3D Capable
Projector
Microdisplay
DarkChip 2
Brightness
3000 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
50.8 cm - 762 cm
Projection Distance
1 m - 10 m
Throw Ratio
1.5 - 2.28:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
144 Hz x 100 kHz
Bulb type
P-VIP 280 Watt
Bulb life cycle
Wall colour correction, ColorBoost II+ Technology, DLP 3D Ready, SmartFormat Technology, EcoProjection Technology, 4:3 aspect ratio support, 2D to 3D Conversion, Acer ColorSafe II Technology, SpectraBoost
Lens
Focus Type
Manual
Lens Aperture
F/2.45-2.9
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Internal
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x component video input - RCA x 3 , 3 x HDMI input - 19 pin HDMI Type A , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 , 1 x network - RJ-45 , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm
Carrying case, lens cover, wireless remote control
1 x VGA cable , 1 x composite video cable
Security Features
GS, FCC, ROSTEST
AC 120/230 V
337 Watt
Power Consumption Stand by
0.5 Watt
39.8 cm
31 cm
13 cm
7 kg
Limited warranty - 1 year - pick-up and return , Limited warranty - lamp - 1 year , Limited warranty - DLP chipset - 5 years
Sound Emission
30 dBA
27 dBA
9JQH C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
