Acer H7550ST DLP 3D 1920x1080 3000 Lumens
Quicklinx: B44PWS00 Mfr#: MR.JKY11.00M
Brightness: 3000ANSI lumens
Portability: Non-portable
Hurry, only 2 left in stock!
£829.34 ex VAT
£995.20 inc VAT
Acer H7550ST projects clear and wide images of up to 100 inches diagonally from as little as 4.9 feet (1.5M) from the screen thanks to short-throw technology, a high 3,000 lumens brightness and a native 16:9 aspect ratio. Due to its ability to project a large picture from a short distance, it’s perfect for consumers who will be using the projector from the comfort of home for enjoying movies, games and karaoke, even within smaller rooms. It’s also a great option for educators for projecting lessons in the classroom.
For added convenience, a hidden adapter enables data to be transferred and projected wirelessly from a smartphone, PC or Chromebook leveraging user’s own Chromecast, an Acer MWA3 MHL dongle or Acer WirelessHD, which delivers 60Hz Full HD 3D movies without having to change settings when used with a HDMI cable connected to a media player. The unique hidden design of the adapter furthers data security, while maintaining the projector’s clean look and feel and reducing the possibility of it being lost.
Two built in 10W speakers provide powerful sound, eliminating the need for external speakers. Deepening the audio impact, built-in DTS Sound increases loudness without escalating distortion, while improving bass performance and vocal clarity. In addition, Acer True Harmony, a customized equalizer, fine-tunes and optimizes the frequency balance to deepen the impact of movies, games and music with enhanced bass and multidimensional sound.
The H7550ST can also stream audio to a wireless Bluetooth headset, sound bar or speaker for additional listening options. Plus, two audio ports extend the ability to attach additional speakers for a powerful surround sound experience.
Acer Colorsafe II provides realistic visuals with its ability to reduce brightness decay and color shift to ensure long lasting color fidelity compared to other technology. In addition, Acer ColorBoost3D leverages an optimized 6-segment color wheel, powerful image processing and advanced lamp illumination to deliver true-to-life colors beyond RGB. Furthermore, with 2D-3D conversion and HDMI 3D ready, customers can instantly enjoy seamless 144Hz 24p 3D movies through two pairs of 3D goggles with family.
  • ColorBoost 3D
    Acer's ColorBoost 3D is a combination of technical advancements that improve optical color performance for all kinds of content, based on color wheel design, specialized techniques to control the projector lamp, and a Texas Instruments DLP chip. Now, Acer presents ColorBoost 3D that provides true-to- life images even while displaying 3D or 2D-3D contents.
  • Acer ColorSafe ll
    Acer projectors featuring ColorSafe II are virtually immune to color decay, such as the yellow or green tint on images displayed by some projectors that have been used for extended periods of time. Acer projectors take advantage of DLP technology to guarantee picture integrity even after prolonged use.
  • 2D to 3D conversion
    The advanced 2D to 3D conversion function makes real 3D enjoyment come true. In the past years, users always suffer limited supply of 3D contents. With 2D to 3D conversion, any 2D signal through HDMI and MHL, no matter a still picture or a video content, will be automatically converted into 3D format by Acer proprietary intelligent algorithm.
  • Acer EcoProjection
    Acer EcoProjection is a complete environment-friendly power management solution that reduces standby power consumption. With Auto ECO feature, projector will automatically enter ECO mode for saving power if there is no any signal input for 5 minutes. Also featured in the Acer EcoProjection suite is Acer ePower Management for customized power-saving configurations.
Acer H7550ST - DLP projector - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses (2pcs) included)
Microdisplay
DarkChip 3
Brightness
3000 lumens
Contrast Ratio
16000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
P-VIP 210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
399 Watt
35.7 cm x 24.1 cm x 9.8 cm
3.4 kg
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3000 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
16000:1 (dynamic)
Image Size
137 cm - 762 cm
Projection Distance
0.9 m - 4.6 m
Throw Ratio
0.69 - 0.76:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 210 Watt
Bulb life cycle
BrilliantColor, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, 4:3 aspect ratio support, 2D to 3D Conversion, Acer ColorSafe II Technology, NVIDIA 3DTV Play ready, 144Hz Triple Flash, ColorBoost 3D Technology, Bluetooth Audio Support
Lens
Focus Type
Manual
Lens Aperture
F/2.6 - 2.78
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x serial RS-232 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - 4 pin mini-USB Type B
Carrying case, 2 x 3D active glasses, wireless remote control
1 x VGA cable
Security Features
Power Source
AC
Nominal Voltage
AC 120/230 V
399 Watt
35.7 cm
24.1 cm
9.8 cm
3.4 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
33 dBA
30 dBA
B44P C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B44P C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.34
B44P C2G 5m Select High Speed HDMI with Ethernet In Stock £21.17
B44P C2G 10m Select High Speed HDMI with Ethernet In Stock £40.63
B44P C2G 15m Select High Speed HDMI with Ethernet In Stock £55.03
B44P C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Brand: Acer
Price Range Ex VAT: 750 - 1000
