The 3,200 lumens Acer H6518BD projector with LumiSense+ is ideal for enjoying home entertainment, featuring built-in 2D-to-3D conversion technology with no extra software required. The H6518BD has a built-in speaker to allow enjoyment of clear sound without the need of external speakers, and also has Bluetooth capabilities to stream audio wirelessly to Bluetooth speakers.
- Acer H6518BD - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses included)
- Microdisplay
- DarkChip 3
- Brightness
- 3200 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 220 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 282 Watt
- 30.8 cm x 21.1 cm x 8.6 cm
- 2.4 kg
- 2-year warranty
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3200 lumens
- Brightness (Reduced)
- 2560 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 115 cm - 762 cm
- Projection Distance
- 1.5 m - 7.6 m
- Throw Ratio
- 1.15 - 1.5:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 220 Watt
- Bulb life cycle
- BrilliantColor, Instant Pack Technology, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.59-2.87
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x serial RS-232 (management) , 1 x composite video input - RCA x 3 , 1 x USB - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 282 Watt
- 30.8 cm
- 21.1 cm
- 8.6 cm
- 2.4 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 31 dB
- Sound Emission (Economic Mode)
- 26 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
