Acer H277HKsmipuz 27" 3840x2160 4ms HDMI USB DP Monitor
Quicklinx: CP82WS00 Mfr#: UM.HH7EE.026
  • Flicker-less technology
    Reduces annoying screen flickering that can cause eye strain when viewing the monitor for long periods.
  • IPS display
    Colors stay true no matter what angle you're viewing from. Share what's on your screen with friends and family.
Acer H277HK - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Adaptive-Sync Technology
AMD FreeSync
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
White, silver
61.27 cm x 21.72 cm x 43.87 cm
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class B
52 kWh
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ComfyView, Zero Frame, Flicker-Less technology, Acer TrueHarmony, Super Sharpness technology, DTS Sound, 8-bit gamma
White, silver
61.27 cm x 21.72 cm x 43.87 cm - with stand
Audio
Speakers
Output Power / Channel
3 Watt
DisplayPort , HDMI , 2 x USB 3.1 downstream , USB 3.1 upstream
Mechanical
Tilt
Tilt Angle
-5/+15
Acer Eyeprotect technology, Acer ColorPlus technology
1 x DisplayPort cable , 1 x SuperSpeed USB-C cable
MPR II
Input Voltage
Power Consumption (Typical)
60 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
Dimensions & Weight Details
With stand - width: 61.27 cm - depth: 21.72 cm - height: 43.87 cm - weight: 4.8 kg , Without stand - width: 61.27 cm - depth: 3.52 cm - height: 36.35 cm - weight: 4.4 kg
Sustainability Information
ENERGY STAR Certified
