This Everyday series monitor saves space and adds elegance to any area. You'll enjoy tasks and entertainment more with fine details and smooth movement, thanks to high resolutions, fast response times and superior contrast ratios. Games are more exciting and films truly cinematic when visuals are vibrant. Plus, the widescreen aspect ratio frames movies and HDTV content perfectly. Set your display as you see fit with Acer eColor Management. A host of ports, including HDMI, DVI, DisplayPort and VGA, let you connect other devices - like your notebook or HDTV - to expand your perspective to a bigger screen. The great sights are complemented by nice sound in models that include internal speakers. Safe for you and your world, Everyday Series use mercury-free white LED backlighting. Acer EcoDisplay technologies deliver up to 68% power savings, further conserving energy and costs. Acer packaging is made of recyclable materials too.
Streamlined
This Everyday series monitor saves space and adds elegance to any area. -
Vivid
You'll enjoy tasks and entertainment more with fine details and smooth movement, thanks to high resolutions, fast response times and superior contrast ratios. Games are more exciting and films truly cinematic when visuals are vibrant. Plus, the widescreen aspect ratio frames movies and HDTV content perfectly. -
Easy
Set your display as you see fit with Acer eColor Management. A host of ports, including HDMI, DVI, DisplayPort and VGA, let you connect other devices - like your notebook or HDTV - to expand your perspective to a bigger screen. The great sights are complemented by nice sound in models that include internal speakers. -
Green
- Acer H236HLbmjd - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Speakers
- Integrated
- Voltage
- AC 120/230 V
- Black
- Dimensions (WxDxH) - without stand
- 53.09 cm
- 2.9 kg
- MPR II
- 2-year warranty
- Display Type
- Diagonal Size
- 23"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Mobile High-Definition Link (MHL)
- Black
- 53.09 cm - without stand
- 2.9 kg
Audio
- Speakers - integrated
- VGA , DVI , HDMI
- Cables Included
- 1 x VGA cable
- MPR II
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Stand by
- 450 mW
- Dimensions & Weight Details
- With stand - width: 53.09 cm - depth: 17.27 cm - height: 40.39 cm - weight: 3.6 kg
- Limited warranty - 2 years - carry-in
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
