- Acer GF276 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 21 kWh
- Power Consumption (On mode)
- 32 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 63.9 cm x 17.89 cm x 44.21 cm
- 4.4 kg
- Plug and Play, MPR II, DDC-2B, DDC/CI, WEEE
- 2-year warranty
- Display Type
- Energy Class
- Class A
- 21 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 85 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Black
- 4.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , DisplayPort , HDMI , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable
- Input Voltage
- 32 W
- Power Consumption Sleep
- 0.48 Watt
- 0.35 Watt
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 10 - 85%
