Product
Acer GF276bmipx 27" 1920x1080 VGA HDMI DisplayPort Gaming Monitor
Quicklinx: CPCWWS00 Mfr#: UM.HG6EE.010
Marketing description is not available.
Acer GF276 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
21 kWh
Power Consumption (On mode)
32 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
63.9 cm x 17.89 cm x 44.21 cm
4.4 kg
Plug and Play, MPR II, DDC-2B, DDC/CI, WEEE
2 years warranty
Display Type
Energy Class
Class A
21 kWh
32 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
4.4 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DisplayPort , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable , 1 x DisplayPort cable
Power Consumption Sleep
0.48 Watt
Power Consumption (Off Mode)
0.35 Watt
5 °C
35 °C
10 - 85%
