Acer G6 series monitors are incredibly stylish with a super-slim profile. Outstanding performance, eco-friendliness and smart use of energy complement the sleek design - all while staying well within budget.
Super-slim
Acer G6 series monitors sport a super-slim profile with an X-shaped stand that lets them fit nicely in spaces of any size. -
Impressive performance
Set your display as you see fit with Acer eColor Management. The great sights are made even better by stunning colors via Acer Adaptive Contrast Management. -
Smart connections
Hook your smartphone up to the MHL port to expand your perspective to a bigger screen while charging its battery at the same time. A host of other ports let you connect everything from game consoles to media players. -
Environment-friendly
Safe for you and your world, G6 series monitors are RoHS compliant, use mercury-free white LED backlighting and meet ENERGY STAR requirements. Acer EcoDisplay technologies deliver up to 68% power savings, further conserving energy and costs. Above all this, Acer packaging is made of recyclable materials, too.
- Acer G276HLJ - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 50 kWh
- Power Consumption (On mode)
- 34 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Black
- 63.9 cm x 17.89 cm x 44.2 cm
- 4.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class B
- 50 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Backlight Technology
- LED backlight
- Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), Acer eColor technology
- Black
- 63.9 cm x 17.89 cm x 44.2 cm - with stand
- 4.6 kg
- VGA , DVI , HDMI , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- 34 W
- Power Consumption (Typical)
- 24.12 Watt
- Power Consumption Stand by
- 480 mW
- 350 mW
- Dimensions & Weight Details
- Without stand - width: 63.9 cm - depth: 4 cm - height: 28.4 cm - weight: 3.96 kg
Sustainability Information
- ENERGY STAR Certified
