Acer G7 Series monitors give you the outstanding visuals you want and the value you need. These stylish monitors fit perfectly in your home or office. Visuals are sharp and vivid on G7 Series monitors, thanks to Full HD resolution and IPS1 technology.
Slim and elegant
The futuristic style of the G7 Series incorporates a slim Zero Frame design that saves space on your desk and lets you place multiple G7 monitors side by side to build a seamless big-screen display. You can tilt the display from -5 to 15 degrees for comfortable viewing. -
Expansive views
Images on the G7 Series come to life thanks to IPS1 technology with deeper black levels, crisper whites and stronger colors, even when viewed from wide angles. -
Vivid color
Acer CrystalBrite technology on the G7 Series offers greater color intensity. You'll enjoy tasks and entertainment more, thanks to the finer details delivered by Full HD resolution. -
Green perspective
The G7 Series monitors are RoHS compliant and mercury free. Plus, advanced Acer EcoDisplay technologies and LED backlighting save power to cut your costs and conserve the planet's resources. Acer also uses recyclable packaging, further reducing ecological impact.
- Acer G247HYL - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A
- Energy Consumption per Year
- 29 kWh
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Microsoft Certification
- Compatible with Windows 7
- MPR II, FCC Part 15, WEEE, DDC-2B/CI, Directive 2009/125/EC, EN 50564:2011, Directive 1275/2008/EC, EN61000-3-3:2008, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, IEC 62301:2011, EN 55024:2010, EN 55022:2010 Class B
- 2-year warranty
- Display Type
- Energy Class
- Class A
- 29 kWh
- Diagonal Size
- 23.8"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 4 ms
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, colour temperature, clock, focus
- eColor Management, Acer Adaptive Contrast Management (ACM), Acer Empowering Technology, Transition Minimised Differential Signaling (TMDS) technology
- Black
- VGA , DVI , HDMI , Audio line-out , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- LED indicator
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 490 mW
- Power Consumption Sleep
- 450 mW
- Limited warranty - 2 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
