Product
Acer G246HLF 24" 1920x1080 1ms VGA DVI HDMI LED Monitor
Quicklinx: BQRRWS00 Mfr#: UM.FG6EE.F01
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
More than 50 in stock
£135.41 ex VAT
£162.49 inc VAT
Slim and affordable
Acer G6 Series monitors are incredibly stylish with a super-slim profile. Outstanding performance, eco-friendliness and smart use of energy complement the sleek design — all while staying well within budget.
Super-slim
Acer G6 Series monitors sport a super-slim profile with an X-shaped stand that lets them fit nicely in spaces of any size.
Acer G246HLFbid - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
56.5 cm x 17.89 cm x 40.09 cm
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut, ComfyView
56.5 cm x 17.89 cm x 40.09 cm - with stand
VGA , DVI , HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
AC 120/230 V
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.46 Watt
Power Consumption (Off Mode)
0.46 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 56.5 cm - depth: 17.89 cm - height: 40.09 cm , Without stand - width: 56.5 cm - depth: 2.37 cm - height: 34.27 cm
Acer G246HLF 24 Bundle deal on Acer G246HLF 24" 1920x1080 1ms VGA DVI HDMI LED Monitor
£230.42
BQRR C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BQRR C2G 5m Select High Speed HDMI with Ethernet In Stock £21.03
BQRR C2G 15m Select High Speed HDMI with Ethernet In Stock £54.68
BQRR C2G Pro HDMI to VGA Converter In Stock £50.42
Diagonal Size: 24in
Response Time: 1ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
