The Acer G series displays engaging high-definition visuals and crystal-clear text on its cinematic widescreen. The brilliant design and simplified functionality make the great value of this monitor easy to see!
Impressive design
The chic black bezel and aviation-inspired base present a polished look that is eye-catching as a desktop PC complement or secondary notebook display. -
Brilliant display
The superior resolution, fast response time, and high contrast ratio provide extra-fine details and smooth movement for your favorite entertainment. The 16:9 aspect ratio frames movies and HDTV content perfectly. -
Straightforward functionality
Just press the input key on the main menu and the G series automatically searches signals across its VGA, DVI and HDMI ports. A press of the empowering key launches the Acer eColor management onscreen interface for adjusting the setup and color to create a personalized viewing experience.
- Acer G227HQL - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 29 kWh
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Black
- 49.9 cm 38.4 cm
- 2.8 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class A
- 29 kWh
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Black
- 49.9 cm 38.4 cm - with stand
- 2.8 kg
- VGA , DVI , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- MPR II
- Power Supply
- External
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 490 mW
- Dimensions & Weight Details
- Without stand - width: 49.9 cm - height: 30.3 cm - weight: 2.5 kg , With stand - width: 49.9 cm - height: 38.4 cm - weight: 2.8 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
