The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced 1080p Full HD gaming, multimedia and productivity applications, providing advantages.
Acer monitors using white LED backlight technology minimize environmental impact while offering superior performance and durability. White LED monitors do not contain the toxic substance mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, resulting in big savings.
Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced 1080p Full HD gaming, multimedia and productivity applications, providing advantages. -
Acer eColor management
A single button - the empowering key - grants full access to the Acer eColor Management onscreen interface. Acer eColor Management provides a variety of advanced controls for achieving the best-possible image quality. -
Dependable functionality
This monitor complies with the Windows 7 operating systems; has undergone rigorous durability testing; and adheres to high safety standards to ensure reliability and comfortable viewing. -
Acer EcoDisplay
- Acer G226HQLHbid - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- Dimensions (WxDxH) - without stand
- 51.1 cm x 3.6 cm x 31.1 cm
- 2.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP
- Black
- 51.1 cm x 3.6 cm x 31.1 cm - without stand
- 2.6 kg
- VGA , DVI (HDCP) , HDMI
Mechanical
- Tilt
- Tilt Angle
- 20
- Cables Included
- 1 x VGA cable
- MPR II
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 20.5 Watt
- Power Consumption Stand by
- 340 mW
- Power Consumption Sleep
- 300 mW
- Dimensions & Weight Details
- With stand - width: 51.1 cm - depth: 16.8 cm - height: 36.5 cm - weight: 2.9 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - carry-in
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
