Acer G226HQL 21.5" 1920x1080 2ms DVI HDMI VGA LED Monitor
Quicklinx: C58XWS00 Mfr#: UM.WG6EE.I01
Everyday Series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Acer G226HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
51.06 cm x 16.92 cm x 36.45 cm
2.04 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class B
32 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
2 ms
Vertical Refresh Rate
75 Hz
Horizontal Viewing Angle
100
Vertical Viewing Angle
70
Backlight Technology
LED backlight
Acer EcoDisplay, eColor Management, 72% NTSC colour gamut
2.04 kg
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MTBF
30,000 hour(s)
MPR II
Power Supply
Internal
22 W
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
0.45 Watt
Dimensions & Weight Details
With stand - width: 51.06 cm - depth: 16.92 cm - height: 36.45 cm , Without stand - width: 51.06 cm - depth: 1.4 cm - height: 31.2 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
C58X C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
