- Acer F7600 - DLP projector
- DLP projector - 1080p
- Brightness
- 5000 lumens
- Contrast Ratio
- 4000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 370 Watt
- Bulb life cycle
- Up to 1500 hour(s) - normal mode , Up to 2000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V
- 480 Watt
- 8.5 kg
- 3-year warranty
Projector
- Brightness
- 5000 lumens
- Contrast Ratio
- 4000:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 370 Watt
- Bulb life cycle
- 16:9 aspect ratio support, EcoProjection Technology, DynamicBlack technology, 4:3 aspect ratio support, Acer ColorSafe II Technology
Lens
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, component video, composite video, S-Video, DVI
Speakers
- Internal
- Sound Output Mode
- Stereo
- Output Power / Channel
- 3 Watt
- Speakers
- 2 x right / left channel
- 1 x DisplayPort , 1 x HDMI , 1 x DVI-D , 1 x USB - 4 pin mini-USB Type B , 1 x composite video input , 2 x component video input , 1 x network - RJ-45 , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 4 x audio line-in , 1 x audio line-out
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 480 Watt
- 8.5 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 5 °C
- 40 °C
- Sound Emission
- 39 dBA
- Sound Emission (Economic Mode)
- 34 dBA
