Acer F7600 DLP WUXGA 5000LM HDMI 3D Projector
Quicklinx: CQ04WS00 Mfr#: MR.JNK11.001
Acer F7600 - DLP projector
DLP projector - 1080p
Brightness
5000 lumens
Contrast Ratio
4000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
370 Watt
Bulb life cycle
Up to 1500 hour(s) - normal mode , Up to 2000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Speakers
Speaker(s) - internal
AC 120/230 V
480 Watt
8.5 kg
3-year warranty
Projector
Brightness
5000 lumens
Contrast Ratio
4000:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
370 Watt
Bulb life cycle
16:9 aspect ratio support, EcoProjection Technology, DynamicBlack technology, 4:3 aspect ratio support, Acer ColorSafe II Technology
Lens
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, component video, composite video, S-Video, DVI
Speakers
Internal
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
Speakers
2 x right / left channel
1 x DisplayPort , 1 x HDMI , 1 x DVI-D , 1 x USB - 4 pin mini-USB Type B , 1 x composite video input , 2 x component video input , 1 x network - RJ-45 , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 4 x audio line-in , 1 x audio line-out
Power Source
AC
AC 120/230 V
480 Watt
8.5 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
5 °C
Sound Emission
39 dBA
34 dBA
