Acer Extensa EM2 series is built around companies' demands for reliable, easy to manage, expandable and thoroughly secure machines with a cost-effective design.
Essential productivity
Presenting dual monitor support, Extensa EM2 series doubles available viewing space and makes it easier to work with multiple applications and documents at the same time. -
Easy manageability and security
Valuable utilities conceived to simplify manageability and enhance security help companies to protect their assets from unauthorized access or data losses. -
Energy efficiency
All components within these desktops are free of hazardous substances, so they have a smaller footprint while helping to drive business success.
- Acer Extensa M2610_E - MT - Core i3 4170 3.7 GHz - 4 GB - HDD 500 GB
- Personal computer - mini tower
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i3 (4th Gen) 4170 / 3.7 GHz (Dual-Core)
- Processor Socket
- LGA1150 Socket
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 4400
- Audio Output
- 5.1 channel surround
- Networking
- GigE
- Power
- AC 230V
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition / Windows 10 Pro 64-bit Edition Dual Load
- 17.5 cm x 37.2 cm x 36.5 cm
- 9 kg
- Personal computer
- Product Form Factor
- Mini tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DVI
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 5.25" , 3.5"
- Slots
- 2 DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 PCIe x16 , 2 PCIe x1 , 1 PCI
- 6 x USB 2.0 (2 in front) , 2 x microphone (1 in front) , 2 x audio line-out/headphones (1 in front) , 1 x audio line-in , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse
- GS, CB, RoHS, PC 2001, EuP
- Power supply
- Voltage Required
- AC 230V
- Power Provided
- 220 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 17.5 cm
- 37.2 cm
- 36.5 cm
- 9 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
